Lathe work
Re: Lathe work
Thanks all for your input.
I decided to try and tackle the lathe work myself, on a WW-II era Atlas lathe.
I started with the simpler (?) parts, the spring retainers for the gear legs, and was surprised by the success I had (and the minimal amount of blood I had to shed).
Here is what I did:
Step 1: Mark the stock for size (plus some extra) and drill the hole while the part is still easy to clamp. then enlarge the hole to 1/4":
Drill before cutting.
Step 2:
Cut the part off:
cut it
cut it
Step 3:
Enjoy lathing. I don't really know if this is the best way to do it, but it worked for me. I finished both ends to correct size, as I had a little bit of extra length when I cut the tube.
lathe it
lathe it
Step 4: Check for fit. Repeat 3 more times.
Re: Lathe work
I also modified the aluminum fittings for the tank on the lathe, removing material from the outer end of the lip to make it flat:
Next, 30 little threaded tube-ends..
Re: Lathe work
Nice work doc! My cousin has an Atlas lathe, he loves that bugger!
Re: Lathe work
I am starting to get the hang of the lathe, still probably doing many things wrong, but I am now turning the threaded tube endings.
I figured I'd share the joy....
Step 1: Chop a piece off your 4130 rod.
I used an angle grinder with a cut-off wheel.
Step 2: Square the end.
The 1936 Atlas lathe
Step 3.a: Drill the hole for the tap (size I I think).
first hole
first hole
Step 3.b: Drill the large hole (To reduce mass for the rosette weld).
5/8" drill, I believe.
Step 4: Reduce the radius of the outer dimension.
reduce radius
reduce radius
(continued on next post)
Re: Lathe work
(continued)
Step 5: Test for fit
Scrap tube for testing
Step 6: Cut off the other end
cut off.
cut off.
Repeat as many times as needed.
Not done yet: Tapping the hole.
Re: Lathe work
Well, these took more time than I expected, but I have a full set now!
full set
full set
DSC_0012 (1).jpg (68.52 KiB) Viewed 4429 times
I hope I counted correctly!
I figured since I have to hand-tap them, I'll do it after they are welded to the tubes.
Any tips on tapping will be appreciated!
Re: Lathe work
Do it in the lathe and chase the threads after you weld them.
Re: Lathe work
I would tap them before welding and then chase them. Using the lathe would be the best since you will be assured that they are straight.
Re: Lathe work
Thanks for the suggestion. I'll give it a try.
Re: Lathe work
When I use the lathe I turn the turret by hand, I don't have the guts or coordination to do it powered.
