CB1 Spar in Comparison to Kelly D
jcadwell
Post by jcadwell »
I'm going to CA to look at a Kelly D tomorrow, and was hoping for some info regarding the spar upgrade of which I have heard rumors.
Is the CB1 Spar the same as a Kelly D spar? Is the analysis performed on the CB1 relevant?
Does anyone have drawings or info on what the upgrade should look like?
Thanks, John Cadwell
Re: CB1 Spar in Comparison to Kelly D
Hi John,
Well, I do not have any experience with a Kelly-D and I'm no aeronautical engineer, but I would not think the CB-1 analysis could be applied to the Kelly-D. They are different airplanes that happen to share a common support organization. One key difference between the two is that the Hatz has a three piece top wing - left & right panels and a center section; the Kelly-D is a two piece wing - left & right panels attached at the cabanes (which are also different from the Hatz).
Perhaps someone here with more experience can shed some additional light.
Doug.
wassbiplane
Post by wassbiplane »
There has been an analysis done on the kelly-D---but a biplane cellule has to be analyzed in its entirety-- Top& bottom wings,
all the flying wires, and especially the N struts , as a true analysis is dependent on the "sharing" of the loads between all the members..
If you draw up a space frame of a biplane cell, apply some loads produced by the wings , and then try to solve the force
diagrams by simple triangulation --you come to a couple of points where the force is distributed by TWO struts---The
question is --How much in each strut. One of the first methods was by the theory of "least Work" which is what I used.
I have done an analysis on my K-D , but--I have mostly 7/16" flying wires (bought VERY cheap) and some old Piper wing struts
used for the N struts (same $ reason), and Doug Fir spars.
If you search the Hatz/K-D website I'm sure you could find the analysis done by Jurg Mueller (sp-??)
Jerry Wass
