Material for turtledeck formers.
Posted: Sat Jul 08, 2023 2:52 pm
by beechdrvr
Hi All,
Time to build the turtledeck. Classic plans call for 3/8 od "soft" aluminum tube.
Versatube looks to fit the bill. Anyone remember what they used? Or, a reason I shouldn't use Versatube.
Input would be appreciated.
Re: Material for turtledeck formers.
Posted: Tue Aug 22, 2023 2:23 pm
I used 3/8 soft aluminum tube from Aircraft Spruce and set it on pins welded to the top of the longerons. I did the same on the bottom of the fuselage.
Posted: Tue Sep 19, 2023 8:35 am
by HC85
I did the same as Ed. Worked out good.
This is filler because for some reason you have to post 50 Characters for the Post to be valid??
