I am starting to build Hatz classic serial number HC-338. I am 1/2 way through building wing ribs. I have 2 questions. First in the wing walk area the spruce span wise strips look like they they are 3/16 thick and 5/8 inches deep. This seems very minimal. Am I correct on the dimensions?
Second is there a reason other than looks to build Aluminum ailerons? I find the wood ailerons like the CB1 has to look just as good. I feel they would be less work to build and perhaps lighter. What are the thoughts on the ailerons?
Jim
Hatz classic ailerons
Re: Hatz classic ailerons
I made my beams from 3/16" plywood x 1" deep. I attached my as-built drawing. My blog for the wing walk construction is here: http://myhatz.blogspot.com/2017/11/2017 ... stuff.html
I think the aluminum ailerons are a copy of the Waco as is the curve in the back of the wing walk. I copied some stuff from the CB1 plans for my build. Worth the $100 to get the CB1 plans.
- 08 Wing - Wing Walk Details-Model.pdf
- (640.82 KiB) Downloaded 249 times
- Site Admin
The Hatz CB-1, Hatz Classic, Hatz Bantam, and Kelly-D plans all are $300 each (Fall 2024) - still a great deal. The Hatz CB-1 plans are the originals that the others are based on and are very complimentary for use with the Hatz Classic and Hatz Bantam builds.
Eric (Web Administrator)
Last bumped by Rick@k23 on Sat Dec 28, 2024 3:39 am.
