Pair of landing gear struts
LarryC
Post by LarryC »
For sale one pair of landing gear die spring struts. Inner and outer shafts are drilled and slotted. The spring retainer are completed. Die springs are included. All that's left to do is to cut one to length and weld on three mounting bushings. Went with different style struts, so theses are extra for my needs. Would like to get $150.00 for the set. Also have an extra set of die spring for $50.00.
tacobfamily
Re: Pair of landing gear struts
Post by tacobfamily »
Would you still have these?
I’m interested in them.
I have a CB1
Thank you
Scott Bell
tacobfamily
Can you tell me more about the springs? Looks like one set is stiffer than the other set?
I’m still interested in the struts too.
If you want to call or text me I can give you my number
Thank you
Scott Bell
